Originally posted by TLC
View Post
MG Maestro Turbo fuel tank?
The actual tanks are all the same on all except the van...BUT there are various layouts for the pipes running to the engine, for example the 1300 pickup pipe is built into the fuel tank sender unit, so tank has no pipes in, but diesel and various others have feed and return pipes fitted to back of tank, swirl pots and suchlike on the inside of the tank and no pipe in tank sender unit. If you have a good tank but for the wrong type of vehicle, it is not hard to plan around the pipes though.
Thats good news as ill look out for oneSure & steadfast.
