Brake master cylinder
  • Brake master cylinder
    Hello All
    I will be needing a replacement brake master cylinder for my 1989 MG Maestro at some point, and having looked on the web and eBay there seems to be a variety of part numbers flying about.
    Can anyone advise which is right part for my car?
    Andrew
    Unipart GMC 243, GMC 244, CDU 3792EVA. All these are NLA from Rimmers. They do have the repair kit in stock at £16.50 which may do unless your bore is corroded or scored. You can also check for cross reference on yoyo part website.
      Thanks Simon
      Andrew
        I've got a servo and M/cyl that I don't need. Seals replaced in master cylinder so ready for use. If interested, make me an offer!
        Membership Secretary
          Thanks Pete, but I've sourced one now
          Andrew
            Hi Pete, I know it's four years and a longshot, but do you still have a spare Master Cylinder please?
              this might fit, can you check the bore size of the old one? are you sure the old one has failed?
              https://www.ebay.co.uk/itm/234111011...UAAOSwMXphA61U
