If the hole is stripped then proper repair is helicoil, which might not be practical. If it still has some sort of grip on the bolt, you could try loctite studlock on the bolt, then tighten it as far as possible and wait until it sets. As long as cable is held in sufficiently when the loctite sets then it will stay put.
