As the title says. I am after some advice on options for what people do when running this level of power in a maestro/montego turbo. Surprisingly I cant find anything using the search function with over 20+years of threads but I know it has been done several times before. I no its fairly quite on here now so if anyone sees this and knows someone that will be able to help I would be very grateful if you could ask them to get in touch.
What is the maximum acceptable level of power/torque/boost the standard items can handle before failure becomes a problem? As I will get it set up to this level first. The gearbox is a good unit with less miles on than the car and a good quality clutch. Probably hasn't done 4k since they were fitted.
Every year since I have owned 500 I have been getting a lot of work done on it, haven't updated any of it on here for a long time. Last year I got the fuel tank refurbished again!!! Got a custom 3" stainless steel exhaust made but retaining the original pea shooter in place for the standard look. Got some welding done under the rear seat. Think thats it for the welding now. Power flex bushes all round, made a massive difference and new rear wheel bearings x2 plus the annual service. The year before I fitted a larger intercooler bought from a forum user, x4 new struts, and more welding! new grooved disks and brembo pads which still ain't brilliant. Braking still needs to be looked at. Along with other bits and bobs I cant remember.
Anyhow I seen these for sale on eBay last year and had to buy them as I knew the chance probably wont occur again, very rare parts The eBay links have gone but I took pictures as a sort of personal receipt. Who knows if they will really make 300bhp, not fused it certainly will be more than standard. Also is there anything that I have missed that is needed? So the spec so far will be:
Thanks Andrew
- Larger intercooler
- 3" custom stainless steal exhaust from the turbo
- Turbo Technics turbo and manifold boost adjustable up-to 21psi
- Motobuild gas flowed head with bigger valves and fast road cam (Currently been rebuild as it has been sitting for 20 years)
- Turbo carb and modified manifold (going in for a rebuild by specialist next week)
Thanks Andrew
