Great did not realize that you could still get them I need one because I fitted a used master brake cylinder blend three of the brakes am unable to do the front passenger because the nipple is heavily corroded left it worrying it would snap off but now I have my brake pedal going to the floor it brakes when pressing the pedal lightly but will not stop when hard braking so I thing there is air in that one caliper.
it helps if you remove the rear brake drums and return the self adjusters to compress the wheel cylinders. order extra bleed screws, if you need to test the master cylinder they should fit it
