Gaz coilovers arrived a few weeks ago. Garage is having a nightmare fitting them. I thought they were suppose to be plug and play! Had to remove all the front brakes to fit the fronts ones. Hope they ride ok as the threaded top of the shock shaft was initially an inch too short but they have got them on. The rears are about 6" to short! He has rang motobuild for advice and he has said new rear top mounts can be made from some other rovers engine mount been cut in half!! Never heard of this before. Anyone else that's fitted them had any problems. Or any problem's with fitting coilovers of any brand like this? Thanks Andrew
Problems fitting Gaz coilovers. Anyone else had this?
My fronts were OK Andy but my rears were shorter I posted I think on Facebook or here about them. Let me try and find it.
Short version I had the rubber rears remade smaller.
EDIT: Found it. Are you on FB Andy? The Maestro was one of the reasons I actually joined FB when I was rebuild8ng it.
https://m.facebook.com/groups/mandmo...5507907301744/Last edited by macca666; 1st September 2022, 04:38.______________________________________________
Maestro turbo No. 108
Alfa Romeo Giulia Veloce Ti (daily driver)(Vesuvio grey)
Mazda MX5 RF LE (Soul Red)
Honda CBR 600 FW (weekend toy)
Instagram & Facebook - mgmaestroturbo108
No i have managed to avoid FB for the last 17 odd years but I keep getting told to join it. If you could copy and paste or screen shot it would be good thanks.MG Maestro Turbo #500
BMW 335I M Sport Convertible
Subaru Impreza Hawkeye Wagon
Rover 218vvc Coupe
My gaz coilovers came a few months ago and fit my 90 MG Maestro perfectly at the top. Getting the bottoms to fit at the front needed a bit of brute force, they were about 1/4mm too narrow. Front top mounts are the mk3 golf hybrids described here.
https://maestro.org.uk/forums/forum/...p-strut-mounts
Originally posted by fatjon View PostMy gaz coilovers came a few months ago and fit my 90 MG Maestro perfectly at the top. Getting the bottoms to fit at the front needed a bit of brute force, they were about 1/4mm too narrow. Front top mounts are the mk3 golf hybrids described here.
https://maestro.org.uk/forums/forum/...p-strut-mountsMG Maestro Turbo #500
Rover 218vvc Coupe
Originally posted by Andy View PostNo i have managed to avoid FB for the last 17 odd years but I keep getting told to join it. If you could copy and paste or screen shot it would be good thanks.
Here's how short I was.....I just got a slimmer rubber to mount made and used it and all was good. Fronts were fine for me just re used the silver top mount from my old ones and or a new bearing in it.....
