Good morning I’m in the process of replacing all the bushes, the rear beam mount bolts need to be cut off (corrosion) does anyone know the correct replacement bolts or at least the measurements of them the new bushes going on are poly they come in 2 parts with a metal inner sleeve,thanks in advance
EFI rear bushes
They are M10 x 90mm the originals have a point on the end (I guess you'll have spotted this already) and the nut is an 'aerotight' type metal self locking one or nyloc , original part number is NAM4646 and nut NV110051. https://www.inracing.co.uk/teesdale-...-parts-centre/ have the original bolts in stock.
