Front wheel bearings
  • Front wheel bearings
    Hi all I have a 1991 2.0 EFI I’m in the process of changing the front wheel bearings and as usual struggling with correct parts, where can I get the tapered bearings (see picture) if not available would the normal 2 part bearings fit, thanks in advance Andy
    You need a single piece bearing, I think it is the same as the MGF ones. do you have a hydraulic press?
      Yes bearings are one piece mgf, as above you'll need a press to get it out and put back in.
        I have a hydraulic press, I don’t think a one piece one will fit as per photo each end is angled hence the tapered bearings, I’m now thinking this hub has been changed before
          you still have half the old bearing in there.
            No both halves removed I thought the later models had a one piece bearing
              the outer race is still in there
                I agree it's still in there
