Evening all
Ok pushing on with the van rebuild (well still taking things apart) and have come up against another issue when removing the rear axle - everything is getting a coat of the blast and powder coat so sending good solid stuff is the key, however! at each end of the axle on the opposite face to the spring mountings there - was ? - something else welded onto the axle can anyone provide a better photo than what i have so i can fab something up to repair this ?
Its looks to be just a spacer block that keeps the Ubolts/axle in place just a photo of a more complete one would be appreciated .. and this is the best of both sides so can't use the other side as a template - that one had pretty much vanished
