Car is a 1988 1.3 City X manual.
For context, the temperature rarely gets above 1/3 gauge in regular driving, and rarely over 3/4 gauge in stop-start traffic which seems totally normal behaviour to me. No physical signs of actual overheating, good compression, no coolant loss, brand new radiator and thermostat, excellent heater output etc. The cooling system appears to be in very good health and offering no cause for concern. Occasionally in the very hot summer weather we're having the temperature will got above 3/4 gauge if I'm stuck idling in traffic for a while but that can be controlled by either turning the heater on or just turning the car off and letting it cool a bit while I wait for traffic to get moving. From personal experience that seems totally in line with cars of this age on modern fuel stuck in traffic on a very hot day.
The problem is the little red flashing light that comes on to tell you that you've overheated is coming on at about 1/2 gauge. The electric fan does kick in as it should and does bring the temperature down but the light will sometimes stay on until the temperature has dropped to 1/3 gauge. Most recently, on very hot days the light will flash when the ignition is on before even starting the car, even if the engine is well below any sort of overheating temperature.
Is there any way I can adjust the instrument pack so the light doesn't come on until, say, 3/4 gauge? Or is this just a Maestro thing?
