Pulse rate for rev counter help ?
  • Pulse rate for rev counter help ?
    Does anyone know the pulse rate for the rev counter ,I’ve a friend who could make the original rev counter work on my engine swapped car from the obd port he just needs this bit of into if anyone has the knowledge ?
    thanks Ian
    The original rev counter is wired to coil negative, so one pulse every time a plug fires, each cylinder fires once every two revs, so should be 4 pulses per two revs, ie 2 pulses per rev, unless I've overlooked something..
    .good luck
    John
