Exhaust downpipe gasket GEX7656
  • Exhaust downpipe gasket GEX7656
    Hi does anyone know where I can get Austin maestro 1.6 s series exhaust downpipe to manifold gasket part number GEX7656
    I had problems finding one last year, some ebay sellers cross referenced it to a 2.0 one which is too big. It is in fact the same as a 1300 one, but that doesn't seem to help much, this https://www.ebay.co.uk/itm/312085148518 has been there for a while, a bit expensive with postage tho'. The other option is to get a 'universal' one, which is just a thin washer that goes around the tubes. If you can't get one a length of copper wire wrapped around the bolts/tubes will do the job if you are careful to avoid gaps and overlaps... good luck
      Good news, xjRover have one in stock http://xjrover.co.uk/
        Thanks John I already bought the link above from Germany it will take a week or so £9 with postage included thanks again
          No problem, sounds like a good deal anyway
