Austin maestro brake disc retaining screw
  • Austin maestro brake disc retaining screw
    Hi does anyone know where I can get brake disc retaining screw never been on the car since I bought it know garage requires 2 for front brakes
    I might have some, if not I can get dimensions & thread size, I would fit some countersunk hex screws similar to these https://www.ebay.co.uk/itm/281748548588 rather than the pozi headed ones from the factory which are generally hard to get out. They are often left off, the only way the disc can come loose is if the wheel falls off...
      Thanks John let me know when you got the dimensions and thread size
        I didn't find my spare screws, but did find a hub, threads are M6, length about 12mm. Ebay has a variety, https://www.ebay.co.uk/itm/304431694840 most similar to original, https://www.ebay.co.uk/itm/122401068234 stainless & a bit cheaper and https://www.ebay.co.uk/itm/317031888034 even cheaper, but 10mm long rather than 12, will do the job I'd say,
        good luck
        John
          Thanks John for the links just bought some from the second link
