Hi All
i have a maestro van ex BT 1989 1,3 500 City model, the rubber bushes at the top of the rear shock absorbers need to be replaced,
one has started to disintegrate, they are not the same as the car NAM 1181 as far as i can tell,
Any advice on how to source two pairs or dimensions to find a suitable alternative would be greatly appreciated,
or the NAM No,
The Below Bushes are available, the dimensions appear to be similar but thought i have better seek advice from the wise,
General Information
- Manufacturer: FEBI BILSTEIN
- Packing unit:
- Quantity per packing unit:
- Thickness [mm]: 19
- Inner Diameter [mm]: 20
- Outer Diameter [mm]: 59
- Material: Rubber
- Fitting Position: Upper
- Fitting Position: Lower
- Interchange Part Numbers: SHU842--APEC, 55-00-0922--ASHIKA, ADBP410052--BLUE PRINT, ADBP410085--BLUE PRINT, S 65 503--BREMBO, 184553--FEBI BILSTEIN, 36729--FEBI BILSTEIN, FSB667--FERODO, 9100007--FTE, BB1046A6, 9100121--FTE, BB1376A5
- OEM Numbers: 0696 995--DAF,696 995--DAF,0 307 113--SCANIA,307 113--SCANIA
Thanks
Fug
