My S Series 1600 Maestro has an oil leak from around the head gasket at the rear of the engine. The leak has slowly been getting worse for the last year and a half.
My local garage has quoted approximately £400.00 to fix the leak by renewing the head gasket.
After careful consideration I have decided to go ahead with the repair. Before I inform the garage, should there be any other jobs I should get done while the engine is in bits.
The garage says the head will have to be sent away to get skimmed. Is this absolutely necessary?
The garage is quite helpful as they are happy for me to supply parts. I’ve seen a Unipart head gasket set on ebay. What other parts would I need?
