Originally posted by The Express Valeter
View Post
Fuel Pump Or Related Issue.
I had it taken to an auto electrician who sussed it in 10 minutes. On the nearside turret is the fuel control unit which is about the size of a cigarette packet and under there is a fuel system relay (sure that is what they called it). It is a black thing which initially they said to try & get another but they repaired it - problem solved.
Originally posted by The Express Valeter View PostI had it taken to an auto electrician who sussed it in 10 minutes. On the nearside turret is the fuel control unit which is about the size of a cigarette packet and under there is a fuel system relay (sure that is what they called it). It is a black thing which initially they said to try & get another but they repaired it - problem solved.
John, unless you have a later Montego your car will have 2 relays side by side instead1958 Ford Consul Convertible. I love this car
Originally posted by Jeff Turbo View PostIt's called a multifunction unit Andy as I posted in post number 5
I was told the other little black thing (much smaller) that is directly underneath the larger item was the relay?
