Hi,
My '95 2.0i Estate (only 60000km/38000 mls) is low at the rear, which makes it look tired.
It has the self levelling suspension but when loaded the car dives even deeper into the springs, is that normal?
Am I right to suspect that the rear shock absorbers are at the end of their life or could something else be wrong? If I need replacements, can anybody supply me brand/partnumbers?
Thanks a lot for any help!
Rgds
Guus
Rgds
Guus
I did purchase the bigger shocks 180mm instead of the original 160mm this might be causing the the rear axle to push down a bit more on the springs. In any case the the ride height and ride is fine and I didn't need to buy different springs.
