I have just acquired a rear facing seat for my Montego estate.
Before I start taking trim out, does anyone know how I will need to make the necessary openings for the seat belt mounts in the rigid side trim? I assume the plastic is pre-weakened on the back so the holes can just be pushed out?
Also how do I attach the top of the rod that carries the upper seat belt mount - does it just tuck (and bolt in) behind the headlining?
Thanks in advance, Richard
