Having problems trying to find out why my son's MG Montego efi won't start.
I know it's fuel related as all the crank, temp, knock, coil, spark plugs etc all all working.
Fuel pump won't prime and won't work except when I put a live and earth straight to it.
Then it's working and pumping fuel but the car still wouldn't start.
I removed the fuel rail and left the injectors connected but fuel didn't blast out from them but the pump is working as ive 'live wired' it and it's pumping. The fuel rail is full of fuel.
Checked inertia switch, changed both relays, changed ballast resistor, put another fuel ecu on it and still nothing.
I'm running out of ideas here so any ideas I can go with anyone?
