Hi Lads.
was after confirmation, on a head im building to TD spec.
Im rebuilding a cylinder head. Not sure if it was a turbo or not.
But the valve diameters all match spec of the TD.
BUT
its obviously got the old type seals in it. (Without the washer built in)
ive got the replacement seals to go in.
But are the old type ok for TD usage?
ive read that on TD im meant to buy 4 new inlet valves,And 4 NEW type seals.
Also, are the Valves the same on turbo and Non-Turbo heads?
the cam lobes are longer on the TD cam thats going in the head,
Than the one that came with the head.
Maybe that gives its original origins away?
BUT
