Oval head round block
  • Oval head round block
    Hi All, can anyone tell me if an oval head will fit on a round block? Cheers
    Measure it Gavin, should do though as the block only has a round hole. Its the head that's slightly different from memory. Or just put a headgasket gasket on the block and see if it lines up.
      oval head/ round block ????? whats this can some one explane
        They line up Jeff, I presume I use an oval gasket?
        Dave - the later turbo engines have an oval hole for the oil feed, earlier ones had a round hole! (From block to head)
          Wrong way round Gavin. Early had oval headgasket face-lift had round. If the gasket lines up on both the head and block without restriction then you should be able to use it. Use a proper turbo gasket though
            Ah, I was half right!!! Thanks Jeff.
              thanks gavin for the explanation
