Is the thin vac pipe & connectors from the ecu to the Fuel trap used on other uk cars and is it avalable anywhere
1.6 S series Maestro & Montego
Sure & steadfast.
1979 Triumph Dolomite 1500HL Pagent Blue From new 76.000 milesNow out of Hibination and into RestorationTags: None
Can someone supply me with a pic of what the origanal one are from the ecu to the fuel trap as my garage has replace them with some other bicycle pump type hose.Sure & steadfast.
Thanks i ll take a look
Sure & steadfast.
You are looking for a vacuum advance/retard hose. Its a thin hardwall vac hose with a right angled rubber connector on one end and a straight one on the other - not from Halfords but from a motor factor. I bought some recently mainly for the right angled connctors on my S Series fuel trap to ECU hose.M&MOC Committee Member - Archivist
Hi Thanks who were you motor factors just in case mine dont have any . I had noticeed that Halfords hadnt got the correct size anywaySure & steadfast.
If all else fails, there is always eBay. this is probably a bit long, but would cut down. http://www.ebay.co.uk/itm/MORRIS-MIN...-/171355738428
I was watching that but need to check to see if the pipe size is the sameOriginally posted by Doctordiesel77 View PostIf all else fails, there is always eBay. this is probably a bit long, but would cut down. http://www.ebay.co.uk/itm/MORRIS-MIN...-/171355738428Sure & steadfast.
I think that the mini uses the same right angle pipe connector and it's still available from the usual mini places, ie minispares.
Try this:
http://www.minispares.com/product/classic/MLH10022.aspx
There are also links to other similar pipes used on a mini.
Ian
I thought that and have ask the mini guys twice .However they cba to reply !!Sure & steadfast.
