O series cambelt tensioning procedure?
  • O series cambelt tensioning procedure?
    Does anybody have any tips on how to correctly tension a new O series timing belt? (On the early 1984-86 version of the O series)
    I seem to remember the official way in the BL manual involved the use of a spring balance, but is there an alternative and safe way to do this?
    Thanks in advance
    1983 (Y) MG 1600
    1987 700 City 1.6 Van
    1988 Tandy camper 2.0D
    1990 Clubman D
    1990 MG 2.0i (spares donor)
    (all Maestros)
    Daily drive: Rover 25 GTi
    Is this the early type with the tensioner bolted to the water pump or later? I normally put the belt on and push the tensioner against the belt so it's tight then bolt it up..
      Thanks for the quick reply, Jeff: yes it is the early type with the water pump mounted tensioner.
      I will be keeping the original tensioner (it hasn't done many miles) unless I find any issues with it when I take the belt off.
      At least these are relatively simple engines to work on, not like the more modern stuff with vernier adjustments on the pulleys!
      1983 (Y) MG 1600
      1990 Clubman D
      (all Maestros)
        If you can't find a replacement tensioner it's the same as a Ford pinto/Transit engine tensioner but you have to do a small modification. Much easier on older engines except when having to change of adjust the alternator as it's on the back of the engine. You'll know what I mean when you come to change the cam belt.
