Hello All
If you read my previous comments on my efforts to repair my Montego estate I kept blaming the rust rat for all the damage, it had caused, however I owe this rust rat a bit of an apology!!!
It turns out that "some" of the water inside the car has been coming from the sun roof, dripping onto the passenger sear, making its way through that, then through the floor carpet, into the rear foot-well and then rotting out the floor-pan.
So, has anyone managed to repair the sun roof, i.e. there is a white coloured rubber band that surrounds the glass of the sun roof.
This rubber band has a "D" shaped section and "should" be incorporated inside the fabric surrounding the glass. I think the idea is that when the roof is closed the "D" is compressed to make a water tight seal.
Right now, this white band is hanging loose below the glass, thereby letting the water through.
How can I fix this, besides sticking some water proof tape over the gap in the roof/glass join, which I have done as temporary measure until next summer.
Any ideas would be greatly received.
kind regards
Africar
So I will get it professionally done next spring. But my sunroof has never opened and I can see the seal is knackered but it never goes out in the wet so never been a priority. I think its rusted shut! I bought a second hand frame in perfect condition few years back so while the headlining is out ail get that fixed. Was worried the seal might be impossible to find.
