Not sure if I'm in the right bit?? just wondered how to remove the wing mirror covers as i want to spray or wrap them? Cheers in advance. Steve
Mirror cover
You would be better masking them up. To remove the covers you have to remove the mirror by putting the mirror as far as it will go upwards and levering out the bottom 2 plastic stay bars behind it, then putting the mirror down and doing the same for the top 2. Be careful as you can break the mirror. After that unplug the 2 heated part plugs to completely remove the mirror. Under that you find the mechanism attached to 2 springs , remove that and you'll find the outer cover is attached using 4 lock washers, once you remove those the cover will come offOriginally posted by Steve O View PostNot sure if I'm in the right bit?? just wondered how to remove the wing mirror covers as i want to spray or wrap them? Cheers in advance. SteveLast edited by Jeff Turbo; 24th November 2023, 11:55.1958 Ford Consul Convertible. I love this car
No worriesOriginally posted by Steve O View PostAhh thanks for that. I think i will be masking it up lol. Dont fancy breaking it,they are as rare as hens teeth. Thanks for the info.1958 Ford Consul Convertible. I love this car
