Antifreeze fluid loss Montego
  • Antifreeze fluid loss Montego
    Hi I have a problem with a in my Montego through the heating duct. The loss occurs from the duct that enters the engine and goes to the heating. Can I get a new part? How could I solve it? Thank you very much for your help
    Montego 1.6 SL 1989
    Golf V 1.9 TDI 2004
    That would be the joint into the matrix. The matix is plastic but the pipes are metal. There is either a flat gasket with two holes in it or two round rubber seals there depending on the age of the car.. The leak is either a rusted pipe or leaking gasket and the only way to find out is to remove the pipes.
    At the back of the engine into the bulkhead are two heater pipes, remove those, using an allen key the are three screws that connect the pipes to the matrix, remove those, then remove the center screw the holds the pipes and remove. Then you will find out where the leak is coming from.
    If you still need to use the car bridge the two pipes that go into the bulkhead and join together so it bypasses the heater
      I really appreciate your help Jeff. Thank you so much I have disassembled it and taken it to a workshop to see if it can be repaired. All the best,
      Montego 1.6 SL 1989
      Golf V 1.9 TDI 2004
        No problem, always happy to help if I can
          I have the same problem. Was it easy enough to get out? I hope it's just a slight weep on the gasket but I know the pipes are prone to corrosion
            Good morning, It is quite easy to remove the piece, the position is not very comfortable. I had the part repaired at a radiator shop, it was in very bad condition with rust everywhere. I have installed it and it seems to work. In my case the loss was for the piece. The piece had no joints so it didn't leak there either. I hope my comments are useful. All the best,
            Montego 1.6 SL 1989
            Golf V 1.9 TDI 2004
              Glad it's all sorted
                To remove is as above
