Rev counter first, as it's the easiest. Most of the cars have the WB wire in the harness from the engine compartment to the instrument connectors. Far as I know all the instruments are interchangeable. You just need to find the other end of the WB wire and connect it to the coil neg. You should find there is already a WB wire on it anyway, to allow the amplifier or ECU to switch the coil. I even found the WB wire in my diesel when I fitted an M16 into it, so that bit of the job was dead easy.
Elec windows are a bit more complex, but as long as you get all the wiring from the same car as the winder mechanisms it should be straightforward enough to fit it all in. Forget about trying to integrate it into the original harness. Just run it separately. More mundane cars definitely don't have the window winder wiring built in. And it can look daunting, with big multi-plugs, but if you can get the whole harness from a car with elec windows and remove all the unnecessary wires you should be able to put it all in. Or you could change the whole harness if you want, but that could create other problems of compatibility if you are unlucky. If you are clueless about electricla systems don't bother trying it, but if you are reasonably handy with wire-cutters, solder and tape it shouldn't be too hard. Having said that, when I got mine two years ago the previous owner had tried to do this and made a hash of it, and I've never got round to sorting it out, so I have a manual window for the drive and a non-working electric one for the passenger.
Derek.
Derek.
