Advice please
    Rev counter first, as it's the easiest. Most of the cars have the WB wire in the harness from the engine compartment to the instrument connectors. Far as I know all the instruments are interchangeable. You just need to find the other end of the WB wire and connect it to the coil neg. You should find there is already a WB wire on it anyway, to allow the amplifier or ECU to switch the coil. I even found the WB wire in my diesel when I fitted an M16 into it, so that bit of the job was dead easy.
    Elec windows are a bit more complex, but as long as you get all the wiring from the same car as the winder mechanisms it should be straightforward enough to fit it all in. Forget about trying to integrate it into the original harness. Just run it separately. More mundane cars definitely don't have the window winder wiring built in. And it can look daunting, with big multi-plugs, but if you can get the whole harness from a car with elec windows and remove all the unnecessary wires you should be able to put it all in. Or you could change the whole harness if you want, but that could create other problems of compatibility if you are unlucky. If you are clueless about electricla systems don't bother trying it, but if you are reasonably handy with wire-cutters, solder and tape it shouldn't be too hard. Having said that, when I got mine two years ago the previous owner had tried to do this and made a hash of it, and I've never got round to sorting it out, so I have a manual window for the drive and a non-working electric one for the passenger.
    Derek.
      Originally posted by Simon
      Yes, you need a divide by 8 circuit (simple electronics) to run a rev counter from a petrol model from the diesel's "W" post on the back of the alternator. I have a circuit diagram somewhere showing how this has to be done and if i can find it I'll post it up.
      Certainly be interested as I'm trying to install a digi dash to a diesel and the revcounter will be driven by the same input I presume..
      The speedo will be the interesting bit
        Diesels were never fitted with rev counters.
        Do do this, make the following circuit:
        http://www.cowdery.demon.co.uk/tacho.jpg
        and you can use a petrol tacho on a diesel montego. Worked fine for me, and I flogged the electronics to Alex from Aachen (3litre) when I scrapped the car.
        The only catch is that the red line is marked at 6000, and the diesel will never reach that!!!
        The circuit is easy to make, and compact. You don't need a circuit board or anything, you can solder all the components directly to the bottom of the IC, and put the lot in a little poly bag.
          A couple of thoughts...
          1. The Diesel engine won't reach 6000 rpm, but it tells you *exactly* what the engine is doing.
          2. My best mate was amazed to see Monty's Rev Counter working when he saw the '4-pack instruments' - assumed I'd fitted the '4-pack' and thought "s*d it" with regards to the rev counter... it's good to see al the Instruments in a car working properly.
          3. You've lost me with the diagram, but as Monty is a 1.6 I'm not fussed. A 'magic black box'?
          4. Why is a mk I Montego's Rev Counter calibrated in, roughly, increments of 167rpm??? Only a minor point, watch the needle move etc., I know...
          Rich Smith
          You can email me here
            Sorry to bring up an old thread. I'm almost an owner of a Montego TD, and want to fit a Rev counter panel.
            I know some late LDV Convoys have rev counters, and the dash is still the Montego style panels, does anyone know if its got a Diesel like red line (i.e, about 4750rpm)? I guess is would work on the Monty?
            Can anyone explain the diagram a bit better too, although I can solder etc, I am not very good with wiring diagrams.
            Neil
            90H Montego 1.6SL (LHD)
            94L Montego 2.0 Countryman TD
            01 MG ZS 180
            97 Nissan Primera 2.0GT
            16' BMW 330d M Sport
            14' BMW X1 25d M Sport
            57' Citroen Dispatch 1.6HDi
              I've fitted Chris' electronic circuit to my father's TD and it works fine. The rev limit on his car is - according to the emissions test read out at about 5200rpm, so why not leave the 6k red line? Power trails off much earlier, so you should usually not end up on the red line...
              Regards,
              Alexander
              http://www.austin-rover.co.uk/index....berbouckef.htm
                Regards,
                Alexander
                Hi Alexander
                Long time no see!!! I did pass Aachen a couple of months back, however, it was late, and I was trying to see if the speed limiter in my 330d was acurate to the speedo or true GPS so couldn't stop!!!
                Why not leave it at 6k?? well, i'm a perfectionist!!! hehehehe
                Neil
                01 MG ZS 180
                • #23
                  Neil,
                  indeed - it's been some time that you have been here. And how accurate is it? I've found all speedos of modern cars (post 1980 for me) to be out more or less (Maestro/Montego -> wide off the mark, Rover 216 -> best so far), though everyone of my old things (Maxi, 1300, 1800) I've put the GPS in, I was unable to tell a difference between speedo and GPS
                  Regards,
                  Alexander
                  PS: Why be more perfectionist with the tacho then most manufacturers? Quite a few Diesels will never touch the red in real life - on the other hand, the rev-limiter of my Honda engined 216 is deep inside of the red area
                  • #24
                    Alexander,
                    The speedo showed 163mph (262km/h) when the speed limiter stopped acceleration, GPS was 155mph (250km/h) dead on. I think it would have gone to 160mph given a bit more time, then again, it does have 231ps and 500Nm torque.... just saving for a BMW fitted chip!!!
                    My expience of redlines is a bit better than yours. My Leon TDi's red was at 4750, but it would rev reluctantly to 5800, and after being chipped, easily to 5000. Our 330d revs to 5000+ if you dont snatch 2nd gear fast enough, and the 320d is an Auto, so it is imposible to rev past 4300 (both have 4800 redline).
                    My 218iS revs to 7200 limiter, especially when it had the gas flowed head, now on my 216i (which also revs to 7200 easily now), both have a 6800 limit.
                    I may be in Koln for wine tasting in October, I will let you know if we travel at normal hours!!
                    Neil
                    01 MG ZS 180
                    • #25
                      Just call in if you are close...
                      Regards,
                      Alexander
