The Unipart code for this part is ADU9826(EVA). The Turbo filter is squatter and fatter than the standard 2.0 filter to account for the higher flow from the Turbo. Specifically it should be 96mm high and 97mmin diameter and with a 13/16 thread.
Other manufacturers part numbers for this are: FRAM PH4835; AP-LOCKHEED CA155; Bosch 0451104026 (only for EFi NOT Turbo); Bosch P4026; CHAMPION B103606; CLEAN DO882/DO926/FO9233; Comline EOF026; COOPERS Z867; COOPERS-FIAAM FT5124; CROSLAND 2076; FIBA F533; FIL FILTER ZP62B; Filtron OP5802/OP5803; FIRST-AUTOMOTIVE L40600; GOODWILL OG101/OG101HQ; HENGST H90W29; Japanparts JFO497; JC-PREMIUM B14003PR; KAGER 100167; KNECHT OC2371; LUCAS LFOS184; LYNXauto LC1120; Magneti Marelli 150180050600/152071758793/154098241450/71758793; MAHLE OC269 (OC237/OC2371-1 looks EFi); Mann W713/28/W71328; MECAFILTER ELH4181/H46/H48; MGA FH1085; MISFAT Z246; MOTAQUIP VFL211; MULLER FO600; OPEN-PARTS EOF410620; QUINTON HAZELL QFL0209/QOF5456; SCT SM164; Sofima S3246R; SOGEFI FT5124; TECNOCAR R106/R506; UFI 2324600; UNICO-FILTER LI710015/LI710028; UNIPART GFE174/GFE189/GFE36/GFE376; Valeo 586048/586074; WILMINK-GROUP WG1217074; Wix AP626/WL7212
With so many alternatives, it cannot be guaranteed that every one is a correct equivalent. Please ensure that the sizes and thread match those above otherwise the filter may not do its job correctly on your engine.
