right i have 2 t16 engines one is from a 220 tom cat and the other from a 620 ti the tom cat has a large coil and the 620 has a small coil whats the difference and which is the best one?
T16 engine
If it is an early 220 then it will be distributer and coil. Possibly the ti could well be wasted spark so no distributer on he end of the inlet cam and what you are pointing at is a coilpack rather than a traditional coil.
Put it this way, I'm considering buying a ti to convert mine over to wasted spark. I'd go with the ti engine if you can confirm it is ws.
Post up some pics and we'll soon tell you.
I thought all 600's were wasted spark.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
