Originally posted by trocse
View Post
This is less likely to be the clutch it's self and more likely the cable self adjuster not working correctly.
You can try to reset the cable to rejuvenate it by grasping the clutch release arm on the gearbox and pushing it down towards the floor against the spring tension of the cable, there might be some initial resistance but then it will move easily any stiffness indicates the release arm pivot is siezing up inside the gearbox. You then release the arm and allow the spring to retake up the slack in the cable. You may need to give the outer cable a bit of a shake to assist the spring to fully adjust the cable.
If that does not work and there was no tightness in the release arm pivot, then a new cable will be needed
