Rover special tools on Ebay
  • Rover special tools on Ebay
    This ebay seller https://www.ebay.co.uk/sch/i.html?_s....m3561.l170197 has a few Maestro/Montego tools for sale including rear wheel bearing tool https://www.ebay.co.uk/itm/375064802539 and the spanner for diesel stop solenoid https://www.ebay.co.uk/itm/375064802540 among others, not essential, but make the job easier and reduce the possibility of things going wrong! The numbers are in the back of the workshop manual, seller hasn't put description of tool on...
    The wheel bearing tool is just a drift from the looks of it, I use a socket and that seems to work perfectly, don't know about the rest of them
      It is, but saves riveting your sockets over The solenoid tool is a 24mm open end spanner with a hex welded on, not hard to make, but saves a 24mm spanner & a bit of work. Most of the tools can be planned around, even the ones for the VW gearbox which was designed in such a way as you need to butcher ordinary tools to fit, I suspect that this may have been deliberate!
        As always John
