Hi All
Sorry I have not updated for a while but I have been busy with other things, so busy I did not manage to get down to the NEC last weekend either!!!!! Anyway back to matters Maestro, time to remove Elvis the A series, still on the transfer list if anyone is interested.
A last picture of Elvis in his old home where he has lived for many years.
The removal was quite straight forward, front pipe off along with the gear linkage, drive shafts out along with hubs and wishbones and the subframe. Then block the engine and gearbox up with a pallet and undo the engine and gearbox mountings and remove the body. Simples!!!
[IMG]file:///C:%5CUsers%5CDavid%5CAppData%5CLocal%5CTemp%5Cmsoh tmlclip1%5C01%5Cclip_image001.gif[/IMG]
Up up and away.
Ladies and Gentlemen Elvis has left the building…………..
Sorry for the weak pun.
Because the gearbox being fitted is a derivative of the 2000 O series PG1 with effectively a different bellhousing to fit the K series I was confident that the main nearside gearbox mount that fastens onto the chassis rail would fit unmodified along with the mounting under the diff. So a MG front subframe was fitted along with the 2 mountings that I was sure would fit which indeed they did. A Brucey Bonus was that the front mounting also fitted so I know the gearbox is in the correct position which means that I have only the main engine mounting to make along with probably a lower engine stabiliser as well.
A picture of the ex rally car “lift the gearbox an inch” mounting which slipped beautifully into place, I expected to have to modify this one.
Finally because you do I, with the dummy block bolted in I popped a head on it to try manifold clearances and to see how it all looked, all in all an enjoyable and fruitful day.
The Manifold that I have nearly finished making is a very temporary measure simply to get the engine running again before the throttle bodies and Megasuirt kick in.
Thanks for looking all comments welcome
Up up and away.
