Curse of Andy struck again today.
Petrol vent pipe done.
Fuel filter on
Spark plug leads on
Coil connectors fitted and on
Turn car over and......no spark
Remove distributor cap and the grub screw for the rotor arm wasn't in properly and is cross threaded.
Cam seal also has a leak so will fix both and try again.
Fuel pump doesn't prime so that's a problem to be sorted.
Will also have to change the starter motor as it's making clicking noises as it turns the engine over and the relay is clicking. Perhaps the wrong teeth amount.
Fuel filter on
Spark plug leads on
