How did you do it Chris, is it fresh bumpers?
turbo 251 - rolling resto
Looking well Chris.
Ah yes, it's quite thin. Now you come to mention it, think I too had to shave-off the rough edges top and bottom so that they sat absolutely flush with the door-skins. It's a good thing in a way, they don't look as obviously taped to the door. And what looks even worse is when you use tape that's too thick and the strips protrude from the door-skins with an obvious gap, which also traps dirt and moisture.Regards
Replacement aeriel fitted. And yes I forgot to tie some string to the end of the cable lol. So had lots of fun trying to feed it thru. After it was finally fitted I then released the mounting holes were not lined up, so I desoldered the brackets and swapped them, also fitted new unbutchered a pillar trim!
