turbo 251 - rolling resto
  • #31
    ok guys some small updates on 251 -
    **fitted and correctly tensioned new alternator and power steering pump belts - this has solved the issues i was getting.
    **fitted new timing belt and tensioner.
    **fitted new headlining as per Jeff thread!
    • #32
      looks spot on that roof lining, only thing is makes other things look dirty!
      MG Maestro turbo 437
      367 Bhp
      • #33
        haha -- yeah your right - need to get that sunroof blind done!
        its not perfect by any means but so much better than it was
        • #34
          Wish you were a bit nearer, you could come and do mine in MGT 396!
          Replacing it is WAY beyond me. Saw ages ago someone saying they found somewhere which did it for £120. Wish I could find somewhere that would do it near me for that price. I'd shake their hand off because I think the labour involved is easy worth that amount.
          • #35
            Looks spot on that Chris, was it completed without to much swearing ha.
            MG Maestro Turbo #500
            BMW 335I M Sport Convertible
            Subaru Impreza Hawkeye Wagon
            Rover 218vvc Coupe
            • #36
              Nice job Chris but grab handles are upside down
              • #37
                Fit all-vinyl sun flaps, easier to keep clean. That blind will respond to a good scrub with soapy water or upholstery cleaner, you could even try baby wipes first but be careful of your new headlining which looks absolutely superb by the way!
                • #38
                  Originally posted by chris-durham View Post
                  Replacement aeriel fitted. And yes I forgot to tie some string to the end of the cable lol. So had lots of fun trying to feed it thru. After it was finally fitted I then released the mounting holes were not lined up, so I desoldered the brackets and swapped them, also fitted new unbutchered a pillar trim!
                  If your replacement aerial was too large, it would have been a Montego one as they're larger
                  • #39
                    ok guys another update
                    **after a trip to the barn i found some std suspension springs - used front and NOS rear - thanks Jeff/Mal
                    distance from wheel centre to arch lip
                    before: F = 310mm R = 315mm
                    after: F = 350mm R = 380mm
                    Now ive got reference values off of Norman who got:
                    F = 360mm R = 380mm
                    So its quite close now to a factory spec car. I also fitted NOS damper (also have NOS rear to fit at a later date)
                    heres how it sits now:
                    **next job was wheel alignment - so took to my local tyre place and gave them the details discussed in the other thread - drives a lot better now - but still not great - and it can only be down to the very soft budget tyres i had to put on it.
                    ** if we look closely here- the eagle eyed - its clear to see why the exhaust is hitting at several places! its a stainless item on it - not sure of brand.
                    from the quick look i took - i think moving the centre section further back may help - a job for another day
                    • #40
                      Hi Chris - yeah they've got site right with the proper tyre profile - suspension ride height - with a slightly nose down attitude. Your ss exhaust resembles a Scorpion system going by the tail pipe? Looking well btw - can't be much to do now?
                      • #41
                        cheers mike - 3 urgent jobs to look at next...
                        1) re-fit exhaust - very very close to copper lines and hits in several places
                        2) very odd vibration - worst between 2500 and 4000 rpm - also seems worse when reving or light acceleration. I had it down to the very worn timing belt tensioner pully. From what i can gather its coming from the back of the engine....
                        3) misfire when coming on boost - it feels like ign related, but all of this is new except coil, maybe something to try. i plan to put boost back to std and work from there - re fueling etc....
                        1 and 2 may actually be linked anyway - i feel in general there is a LOT of vibration through the car - not sure if this brand of exhaust is to blame or not?
                        • #42
                          It wouldn't be a maestro if there wasn't a rattle from some where!! Behind the dash is the norm
                          367 Bhp
                          • #43
                            Is it a virbration noise? If so it's normally the downpipe knocking against the xmember
                            • #44
                              yes, something else to check out - once i get under it
                              • #45
                                well a lovely warm evening to be lying outside under the mg LOL
                                after about 2 hours of battleing with it, the full exhaust is off!
                                so tomorrow or sunday i will try to refit it - correctly this time so it doesnt hit the copper lines under the car!
