Mike to be honest no, just straight swapped it am guessing would prob work better with new higher amp wiring and relay, but I had no problems either
MG Maestro Turbo 400 bhp My Blog
I would look into that Peter just in case as I was advised against that - thats way I wondered what you did.
Only problem I had the 044 pump is bigger than the OE pump, so had to trim protective foam that goes round the pump in the cradle, wires on the OE are push on, the 044 pump there bolted and came with out fitments had to buy seprately off ebay, am sure I bought 9mm outlet 19mm inlet I can double check if neededLast edited by charliecosworth; 21st November 2014, 14:44.MG Maestro turbo 437
367 Bhp
The 044 consumes more amps than what the OE wires can handle Peter. I would seriously consider using OE wires as a on/off supply to the relay only. Then heavier gauge wire feeding directly from battery to relay. Could potentially fry your wires if you don't.
Yes I just checked the specs and it has a max current draw of 15.5amps
So you'll want a 20/25/30 amp fuse and suitably rated cable too.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
been a while since i updated my blog...
plans this year 400bhp plus
to do list..
Battery in boot conversion, rewire the petrol pump with right rated amp wire
GTX30 76R New turbo
Charge cooler
Double width intercooler, hoping these items will push it over the 400 bhp mark
started today with battery in boot conversion alloy battery tray fitted, with live lead from BMW diesel estate (these cars have battery in boot) all went well.
managed to get charge cooler good second hand one PWR one this one below
http://www.chargecooler.co.uk/index....roducts_id=195
charge cooler rated at 450bhp, going to run with double intercooler for max cooling, cooler rad i think is going to be from MK1 focus RS which is small and slimline to fit along behind front grill this one below will just need custom brackets which i will make.
http://www.ebay.co.uk/itm/AIRTEC-For...item58a39a6bef
my buys
any ideas or advice feel free to commentLast edited by charliecosworth; 14th March 2015, 20:58.MG Maestro turbo 437
367 Bhp
I assume you are routing it:
Turbo--> Charge cooler --> Intercooler --> Carbwww.maestroturbo.org.uk - The Tickford Maestro Turbo Register
The rs chargecooler rad looks small for a 400+ car i think Peter?
Good stuff Peter - you'll have fun cramming al that in.
