Updates from the garage
Click on the photo for a bigger version.
Yes it'll work but you'll need to fill each tank seperatly and also you'll need a vent for the extra tank vented outside the car quite high up to prevent syphoning
Two Corbeau recliners, light weight for more comfort seat belts (from Car
Builders Sollutions, www.nfauto.com - just £35 a set), and a foot rest for
the navigator now in, the seat frames were built from scratch as the
universal frames from Corbeau were considered not strong enough for
rough-roading...the silver-foil sandwich put into the roof will go under the
front carpets...a decent MG wheel is needed...
Mini van tank for longer range, but will a pipe into the main filler tube
empty the contents unaided, on gravity alone? Only testing will see if this
works - there is an off-on tape in the line...
More substantial filler tube to the Mini Van tank now in place, filled by
the rear quarter panel...
After seeing the rusty front turret earlier, the body-shop have put in massive reinforcements to the front end…
