Maestro 1600 LX auto 1990
  • Maestro 1600 LX auto 1990
    Hello
    I have just entered the world of the Maestro
    with a 1990 Maestro 1600 LX auto H39EAY
    Incredible Condition 17000 miles and looks genuine Drivers seat nice and hard, steering wheel not worn etc etc
    Not much history other than Gov UK Mot reports
    Believed to have come from an Estate
    This now sits side by side with a Triumph Herald also H registration
    Any one have a Maestro in Leicester area
    Welcome, seems a nice maestro, you should put some pictures up, and the herald
      can you help out
      my Maestro has standard push on Hub cap trim, I have bought some Vanden plas Trim looks as though it needs a different wheel nut with a flange to avid breaking the plastic any ideas
        If it is designed the way it sounds from your description, it sounds similar to the Rover SD1 set up..not sure what threads SD1 nuts are, but it was quite Triumph biased, so might be lucky. SD1 had springs behind the wheel trims, spigot, plastic washer and flange on the nut.
          Can’t wait to see photos, do like a herald welcome to the board
