PG1 Gearbox selector shaft oil seal.
  • PG1 Gearbox selector shaft oil seal.
    I appear to have lost all of my gearbox oil out of the selector shaft seal
    is it possible to replace in situ?
    is this the correct part?
    its a clubman TD - http://www.rimmerbros.co.uk/Item--i-CDU71
    If you have lost it all and driven it anywhere it is likely the gearbox is buggered! You'll have to drive it for a while to find out though!
    Yes it is the right part, and no you don't have to remove it. Just prise the old one out and drift the new one in. The problem you'll have is access to get a clean purchase to either remove to especially to drift the new one in.
      I also need the dust coverof the selector of the gearbox, does anyone know where I can find the two pieces? Thank you
        Look on the same website. rimmers bros also deliver world wide
          Do you know what the part reference is? Thank you
            boot is bnp 3287, seal is dbp 9434 or cdu 71
