I need to change one of the front bearings again... getting a bit tedious now!
Has anyone else bought one of the presses off eBay? They come in at less than £100 and Im considering this, rather that taking hub to the local garage... again.
I have spare car hubs, and thought I'd fit bearings, less the drive flange as mines a van.
So, anyone gone DIY all the way?
Extra grease in everything that is supposed to be greased for life always works for me...I've drilled & tapped new ball joints to add grease nipples on Maestro, Transit & VW LT over the years, always took more than one pump of gun to start inflating rubber...and one pump is a lot of grease in a tiny ball joint... I did some work at a print place years back, they had a solvent fire started by a sealed bearing that was a week old (not fitted or supplied by me fortunately)...
) have taken the inner races off. A useful trick from the pit is, if bearing inner races are out turn a welder up high & put a ring of weld around the inside of the outer race, when it cools bearing will be keener on coming out, same trick works on inner race, but you have to do it when it is still hot. Good job they feature on MGF, if front wheel bearing stocks ran out, we would all have real problems in the not too distant future!
). I was thinking about making a normal taper roller set up out of more or less worthless hubs & spindles that I seem to have quite a lot of..so that I could use them up & also I would guess that if I either put a grease nipple in or repacked them every time I did the timing belt they should last more than 500,000 miles, there is room for bearings bigger than a transit front wheel bearing, they usually last over 300,000 carrying a lot more weight than a Maestro. I did 850,000 on original wheel bearings in a 3.5 ton sherpa... Anything that has properly designed bearings (Old Land Rover/Range Rover, Jag, old rwd transit/sherpa/merc etc) will very rarely need the bearings replacing, anything with crappy toyown throwaway bearings (newer transits/all fwd vans/fwd cars/toyota corolla etc) will need them replacing more often than I'd like.....It will not be a financially smart move, but will save me from having to take spare bearings/removal gear or tranquilsers with me whenever I leave the country
. If you ever feel the urge to learn some new swear words simply tell an old mechanic that you think that Ford were very very clever using fwd bearings in the rwd vans so that everything is all the same and you are surprised that the designers did not get an award for their fine work
