Rather than continuing with the Panic Stations! thread, I thought I had better start one with a more specific subject. The basic situation is that I have no spark at the plugs at all. There is a new coil (confirmed OK), new HT leads, new plugs and the ECU has been sent away for bench testing and returned as working OK. Using Jeff's loaned ignition analyser boxes, they indicate that at least the wiring and sensors are behaving as expected. Pictures below taken during the last test run and show the static, dynamic and fuel ECU test results.
A time-served auto electrician has also been through the system and arrived at the same conclusion I have - basically no **** idea! His suggestion is to find another turbo owner with a running car and carry out and ECU swap to prove one way or the other if its a good 'un. I've made contact with a member in Chichester and currently waiting a response.
