I have a 1993 1.3 Maestro Clubman and just bought a haeadlight assembly. The one that arrived is from a 1985 model.
The configuration of the electrics are different as is the area at the back where the main bulb goes in, it is a screw fixtue instead of the rubber boot.
Will this be ok to put in to a 93 model and if so what do I need to do to make the electrics ok?
S
S
