Turbo Feed Pipe
  • Turbo Feed Pipe
    Hi All,
    How do i know if the turbo is getting enough oil from the pump?
    Many thanks
    Jamie
    MG Turbo No.172
    Jamie
    MG Maestro Turbo No. 172
    Land Rover Defender 50th No. GB093
    Jaguar XJR100
    Mercedes Vito 122 SportX
    Ford Sierra Sapphire Cosworth 4x4
    Audi 80 B2 Quattro 2.2
    If it doesn't it'll blow the turbo up. The feed pipe is connected at the rear of the oil pump to the turbo via a 10mm metal pipe. Why do you ask?
      My turbo is knackered, so having a hybrid one built. Had to fit an efi pump when the engine was rebuilt, so using a tee on it. One side for the oil pressure switch, the other for a braided feed hose i had made up. Just wondering if this has contributed to the turbo fail?
      Jamie
      Jaguar XJR100
        Well that I wouldn't know as i don't know the car, the difference with an efi pump is it hasn't got the oil feed hole. You could just drill through the blank and tap it to fit the oil feed. Making sure all is clean after though
