Maestro Turbo Heater
  • Maestro Turbo Heater
    Hi Guys
    Maestro Turbo No. 384.
    With the onset of cooler damper weather having problems with the heater, or rather lack of, in the Maestro Turbo.
    All pipes are connected and water seems to be flowing, but even on hot setting the air coming out of the vents is at best luke warm.
    Any ideas please
    Thanks
    That could be a few things, Thermostat to cool, blocked rad, blocked matrix pipes or could be blocked rear water pipe which is most likely. Have you tried flushing the system including removing all the coolant pipes? The rear water pipe is behind the carb and does get rusty over time leading to blockages. Its connected to the thermostat housing and heater pipes coming out of the bulkhead
    1958 Ford Consul Convertible, new hood going on
    1965 Ford Zodiac Executive. Sorn for the winter
    1984 MG Montego EFi in black. Digital dash and bring worked on
    1984 MG Montego EFI in red. Digital dash and being worked on
    2004 MGZT V8. What a car, wife's daily atm
      Thanks Jeff.
      Will give it a go this weekend, weather permitting.
      Tom
        Don't forget that the face level vents only ever blow cold air. The hot air comes out of the screen or foot vents only.
          Thanks Mr ETV. Was gonna take a look today, but the weather is awful.
          Still there is always tomorrow, the benefits of being retired.
          Tom
