Why?
Maestro TD needs new CV Joint, all ebay ads reject it
I ordered one two years ago from a local motor factor , going by the reg no , they got me one that did not fit : different number of teeth . I took the old one there and they ordered the right one . after checking and double checking it seems that the computer was right going by the registration number but my engine and gearbox most likely may have been changed a few years ago hence the mismatch , I know ebay usually is cheaper than the shop but failing that bite the bullet and go the local motorfactor
I have fitted these and the joins are very good but the flange on the nut is a bit big and sits on the radius of the sub axle. the nuts they sell separately are fine.
https://www.jandrcvjoints.co.uk/rove...cv-joint/JR337
- 2 likes
turbo diesel montego, but the part number is the same for the maestro.
https://www.jandrcvjoints.co.uk/rove.../cv-joints-510
The CV Joint was fine Robert, I had it fitted by a garage that I use and it is silent in use and I am very grateful, I think that you have helped me before with a front suspension unit that collapsed, you found a replacement on ebay, so thank you again for that WOW
Cheers Tom
