Maestro Oil Filter
  • Maestro Oil Filter
    I have a Ledbury Maestro 1.3L. engine no AK 87332881 . My garage & I are having trouble sourcing an oil filter. previously we've used Halfords HOF 209 (they don't so them any more); FRAM PH2869 ( number have changed completely); WIX WL 7213 (this might still be available. The WIX one has an outside diameter casing of 76mm; rubber sealing ring o/d 71mm, i/d 61mm; Thread 5/8-18 UNF. Howcver we've seen one on the internet, which has the same dimensions except the thread is 13/16 - 16UNF-2B . Does anyone know the source of the correct oil filter for my model?
    If you have any Triumph specialists/owners nearby, the should be able to help, 1300/1500 Triumph engines with spin on filter were 5/8". As far as I know, this one should be correct https://rimmerbros.com/Item--i-GFE119
      Many thanks, it looks good. I will explore.
        Just did a search for the Fram part number and found this: https://www.midlandchandlers.co.uk/p...-ph2869-ea-063 HTH
        Club Secretary
