Hi all,
Does anyone know the difference between the su fuel pumps for A-series Maestros and Minis et al? Su list them separately on the website with different parts numbers but give no specifications (I probably should just ask them).
I've been trying to find the size of the inlet and outlet but can't find that either, I'll have to measure the one on the car. I'll replace the rubber lines whilst I'm fitting a new pump.
Has anyone got any experience of fitting a non su fuel pump? Is it worth it or just pay double for the su?
Mine seems to need quite a bit of priming before she'll start which is why I'm looking. I replaced everything bar the starter motor earlier in the year so believe this will be the most likely cause. Everything else is set up fine and she runs well just a long cranking when she's been left a while.
Thanks in advance
Thanks in advance
