Having some difficulties with my 2.0Efi engine. It’s running somewhat on the rich side (0.85 - 0.9) and at idle the rpm is unstable, ranging from 900 to 1100rpm. any ideas what’s causing that ? Thanks, Chris
Running a bit rich and unstable rpm at idle
When I read the AR tune-up instructions that I should hear a 'click' when taking end of idle plug lead on and off (3 times). Does that click from from the idle plug itself or a relay under the bonnet ? ChrisOriginally posted by Jeff Turbo View Post
