Hello again,
I'm after your expert advice as always (telling me to take it to a professional is a valid suggestion but not likely at this time..).
So I finally got around to arranging having my tailgate windscreen swapped over to the one I had repaired almost a year ago. They're coming on Wednesday afternoon.
In preparation I've taken the tailgate off to fit the new one. So far so good, came off ready enough and got the wires fed in to the new one with relative ease.
However the big problem is it doesn't seem to sit properly. The bottom of the tailgate sits proud. The latch catches but the panel is sitting higher at the bottom of the windscreen (not fitted) than the line of the car and I've got large gaps above the lights.
Is there an order I should be adjusting the bolts for instance to give me the best chance? The panel seems to be true to the car, just not sitting right.
Thank you
A+
I didn't get a photo of how it's sat, sorry
Thank you
A+
